1 - 2 of 2 Posts
i have a 98 honda 450es the eletric shift will not work. i have done a continuity test on the shift buttons, i replaced the shift angle sensor, i pulled the eletric motor off and put 12 volts to the motor and also reversed the pallarity on it and it works fine. i checked all the fuses, but when i have the motor running i have no power to the shift motor and the neutral and reverse lights are staying on does anyone have any suggestions to what i need to do next and also has anyone ever had this problem. thanks :confused:
1 - 2 of 2 Posts
