I'm having trouble getting my starter to spin the motor over. All it does it click when I push the start button. It will work intermittently. Any suggestions on what I need to do to begin fixing the issue? Thanks in advance.
Is the battery good? What voltage does it read on an ohmmeter?
Can you confirm all grounds (earth's) are clean and have a good connection?
I checked your other post, Is the bike a 95 300, or 98 ?
with a hot charged up battery, I'd be thinking starter brushes... That click your hearing is the starter silenoid
Certainly a possibility however, a bad (dirty/corroded) ground could have the same effect.
Also... A recently charged battery may show good voltage, it's always worth checking the voltage 6 to 12 hours after charging to give an accurate reading.
Could be, a starting history would be nice to have....lol (DETAILS!!) are a must have for diagnosing online. :)
Reactions: SamUK
loose ground ?, bad/weak battery ?..just because a battery shows 12 volts ?..DOES NOT MEAN IT HAS ENOUGH CCA TO CRANK IT OVER !. ( thats cold cranking amps for all you newbies )..lol. 12 volts is not what spins starters over ?, ITS AMPS !!. oh, and bad starter brushes will also cause your issues :).
Review the service manual
Take the starter off—and pull off the end cover.
if it looks like mine then you’ll need to rebuild it with a brush kit or rebuild kit. Or take it to a battery shop—sometimes they need to be turned on a lathe.
Or buy a new starter
Auto part
