Hello all! I'm new to the site as well as atv's. I actually obtained my first one yesterday which is a '98 Fourtrax 300 4x4 which I traded a johnboat/trailer setup for.
I picked it up yesterday with the understanding that it needed a battery but would kick over and run fine. I watched the previous owner hop on and kick it over with no problem. It only took two kicks. We loaded it up and I brought it home.
When I got home I unloaded it and hopped on. I kicked until I was exhausted. Yes the key was on, switch on run and the fuel on. Being that I unloaded it in the field next to my house, I slowly towed it over to my house to put in the garage, probably about 400 yards that it was towed.
I then said screw it, went and bought a battery. Put the battery in and it turns over but won't crank. I tried kicking again and nothing. I originally tried with no throttle, then light throttle. I messaged the guy I got it from and he said hold it wide open and kick it. Tried that too and nothing. I even used some starting fluid but no change.
Being how it's old and worn out, I intend on doing a long term rebuild. I Removed the rear fender and air box. Drained the fuel and put in fresh non ethanol. I turn it over and I noticed a lot of compression/pressure coming out of the carb which sprays a little fuel. Is this normal?
Also note that the choke cable is broken. I have one on order as well as a carb kit to freshen it up. But it's also around 95 degrees here in south GA. The previous owner claimed to have just done a top end. I have no reason to doubt that.
Basically I'm looking for any advice. I did test spark and compression. Both are good. If the compression through the carb is normal then I am going to have higher hopes with the carb rebuild.
Sorry for any stupidity I may have posted. As I said, I am new to atv's. I haven't had anything since I used to race motocross on 2 strokes back in the day.
Thanks in advance.
Thanks in advance.
