Intermittent failure to shift to reverse. Angle sensor replaced, no luck. Now using the provided wrench to shift to neutral and then usually can shift to reverse. Read about reverse shift sensor issues and viewed photo on line. My unit does not appear to have the sensor? The Foreman is in good condition and has not seen rough use. Any ideas on the suspected problem? Tks!...Mike
welcome to the forums. pull the cover off the front transfer gears, clean out the old grease, repack with fresh grease, see if that's helps ?.
Believe I zeroed in on the problem. The reverse button appeared to be sticking and not always locking in place. Disassembled, lubed, and re-installed. Problem appears to be resolved. Thanks for the suggestions!
geee..wish all our problems was that easy !!..lol. glad ya got it fixed !.
