Unfortunately I let gas go bad in this machine and trying to get it running now. Ran great before my neglect. Pulled carb and cleaned thoroughly. It will now idle fine but will not rev up unless I mostly block off the air intake. Diaphram appears completely intact. I put fuel air mixture screw back to its setting. Fuel flow to carburetor is good and I put a in-line fuel filter in case junk in tank and pulled carb and completely cleaned everything again, but same result. It will only rev up if I block the air intake
Please and thank you
