1 - 10 of 10 Posts
Look in the repair and maintenance section of the forum the first stick by Saber6 is what your looking for.
Timing chain guide is worn possibly causing slack in the chain
1998 300 honda 4X4
the timing chain guides are new! the lifters was rattling bad and i came here to learn to adjust the valve lifters and that stoped a lot of the rattling but its still got some rattling when it idols you barley here the rattling but as it gets warmer it gets a little louder what could cause the problem?
Im not real sure but my quad does the same thing as it gets hotter the oil thins or gets looserwhen you have an ohv engine with no lifters you have basically a solid valve train in a sesns so you may hear a rattle and more defined as it get hotter.
Also does you quad have a back-up kickstart? if so the detent lever may be the culprit.
Did you adjust the valves with a warm motor?
NO No No NO You never adjust valves on a warm engine.... You always do it on a cold engine let it sit overnight then make your adjustments.
1 - 10 of 10 Posts
