lol, I know my trx300's and trx350's ( old school )..and new trx350's..lol.Yep, Shady is right, you’ve either got a 97 300 fourtrax or an 87 350 Foreman.
Post a picture, we like pictures!![]()
I’m still learning, knowledge comes with age... Must be a good advantage of yours lmaolol, I know my trx300's and trx350's ( old school )..and new trx350's..lol.Yep, Shady is right, you’ve either got a 97 300 fourtrax or an 87 350 Foreman.
just knowing is half the battle !..age is a bonus..lmfaoooo.I’m still learning, knowledge comes with age... Must be a good advantage of yours lmaolol, I know my trx300's and trx350's ( old school )..and new trx350's..lol.Yep, Shady is right, you’ve either got a 97 300 fourtrax or an 87 350 Foreman.
I’m getting pretty good with the 300’s though.. (I think)!
98 motor will swap fine, the issue is most likely either carb related or CDI related, you can just use your carb and CDI that's already in your machine though and the motor should not have any problems. The CDI is the "little box in the front".wow great info guys thats a lot this really helps me out
the machine is just for a farm where it won't be used hard so to say just to go turn on and off water valves and pruning and to go from one side of the property
so my next question is i have a friend with a 98 fourtrax 300.... its beat up cosmetically but runs great......
other then the fact that it will just die sometimes at idle 30 seconds after being started up randomly.....
to me it sounded like a low oil shut off but the oil is full and it dose not burn oil and if u leave it for a few days or so it will run fine...
i am in the middle of a rock and hard place of what yo do as if the motor from his 98 will fit in i will just swap the motors and keep the electrical on the machine and it should just plug in to the other one
just got to find out why his 98 ramdonly dies??
he seems to say theres some electrical box in the front if his 98 that may be the problem of it dieing out ?
thanks again guys this was a great help so far
one again thanks for the info on the hole situation
anyone have any leads on anywhere to just order a new motor ?
or somewhere in BC canada that rebuilds them?
