1 - 20 of 28 Posts
I need help finding parts for my 1997 fourtrax I can’t tell what it is cause the sticker is faded so can anyone help?
151085
Use your VIN.
Reactions: Goober
download the service manual and check parts links in my signature block below
Manual will show where VIN is stamped—usually the flat plate betw the two front frame downtubes
hopefully this is all original andyou restore it using only OEM parts
2003 Honda TRX350 Rancher 4X4
if you are looking for parts I would recommend partzilla.com They go back to 1976. Ebay would be the next option.
Hondapartsdirect.com is a good source for parts, usually things are a lot cheaper there, Partzilla price matches hondapartsdirect.com. so if you have over $150 worth of parts, partzilla will give you free shipping! Also like every else said you most certainly have a type 2 honda fourtrax 200. Hope this helps :)
That looks like it is only for Honda cars...
I use Rocky Mountain atv, Partzilla and fleabay. I also visit my local Honda parts counter because they can access secret Honda parts inventories.
If you know the part numbers you can find what you want. Beware sellers will describe some parts as OEM replacement, equivalent or use other weasel words to describe aftermarket parts.
cheap cycle parts is a little better or for some things you can get Rocky Mountain atv like goober said
1 - 20 of 28 Posts
