Hey guys,
2 quick issues i want a second opinion on.
1)
My neutral light is having some issues. Recently its been blinking on/off randomly, or staying off all together. I know form other posts, that if it was off permanently, i would not be able to use the electric start (or so others say) but i still can. I tried wiggling the connection in the head unit and also unplugging and re plugging the connectors on the engine next to the right side foot brake (what i understand to be the reverse, neutral, and oil temp lines).
I recorded it going nuts, check the video.
No avail, Any ideas?
2)
I replaced my front brakes with a aftermarket disk brake kit (from SUPERATV) and have never gotten it to work super well over the past year. I have done the anti-air bleeding maintenance about 5 times now (once every few months) and i still have a very mushy brake, even sometimes barely engaging at all until i pump it like 5-8 times.
I am not super knowledgeable with now fluid based brakes work, but as far as i can tell, i have no leaks (ever time i re-bleed it, i never have missing fluid) and there is no-longer any air in the system (i never get air coming out when i bleed it to try to improve this issue).
Do you guys think i need to just replace my whole handlebar brake unit? It is over 20 years old now, maybe the piston is just shot and cant hold the pressure properly?
___________________
As always, thanks guys!
1)
2)
___________________
