1 - 1 of 1 Posts
Getting .3 volts from pulse generator although ohms our correctly, replace pulse generator and stator, still have same voltage from pulse generator, check output to coil from CDI nothing, replace CDI.
Re-test,. Same readings everywhere still no spark
Testing blue/yellow wire from pulse generator, with or with out being plugged into harness still get .3 volts .ac .. on fluke meter .
Does the flywheel have 2 pick up points and one is bad?
Any help on this ??
1 - 1 of 1 Posts
