Okay, im working an a honda 300ex. It came to me barely running, loss of power, hard to start. While cranking or idling gas is being blown back out of carb throat every compression stroke. A constant in and out of vapor. Pulled valve cover, timing chain was tight but approx 90° out. Pulled head and replaced bent valves. Put everything back together according to specs. Cranked up and ran fine for 10 seconds. I shut it off to finish connecting odds and ends. Tried to start, won't start. Some minor blowback through carb again. Pulled valve cover at TDC and cam was out 12 teeth. Reset cam to align marks with head surface. Put it together. It started right up. I shut it off with a smile. Came back 2 minutes later and it won't start. Pulled valve cover again, cam off again approx 12 teeth. Guys, what am I doing wrong. Chain tensioner seems to be working fine. 3 times I reset the cam timing and it went out of time by 12 teeth each time when at TDC. Chain is tight, all teeth look great. Any ideas on why or how this is jumping time? It a neighborhood kids quad, help! Thanks in advance.
Bruce
Bruce
