1 - 16 of 16 Posts
I am sure some vets will notice my name and vehicle, but over last 4 years i have been on/off (mainly due to university) rebuilding a trx300fw i bought.
- rebuilt rear differential
- new rear axle
- led headlights
- led tail light
- led indicator lights (neutral, oil, reverse)
- fixed as much plastic as possible (zip tie method)
- de-bent bumper
- added a 2k lb winch
- 12" wheels
- front disk brake kit from superatv (still working on it. Not working perfictly)
- wire wheels and ruatoloim paited a lot of body (not sticking as well as i would have liked)
- changed all fluids
- adjusted valve spacing
- rebuilt carb
Here is a video of its first day offroad (3rd time that day)
Cheers to all those who helped.
Sent from my SM-G930T using Tapatalk
Excellent job, looks like a nice trail too, I love the ones that seem unused never know what you’ll come up against!
Great job , finished with a video -------What's up with the green tank , paint job and decals or is that color available by you ? I have never seen that color before
I think that paint finish is known as HondaSaki!!
Reactions: fishfiles
Was just the color paint that i had available.
Could not find a decent paint that matched rest of atv.
We’re only fooling around Orvis, I do the same from time to time, use whatever is avaialble to get the job finished up and then change at a later date.
Discussion Starter · #9 ·
I took no offense. Just wanted to give the answer.
You did a good job on the Hond-saki green , I thought it was a color I never seen before cause are you from Downunder ------ did you tape the decals or buy new ones , I was going to buy decals once and they want like 4 times more for the right than the left or maybe that was vice versa , if you taped them you did a good job
Discussion Starter · #11 ·
I just used tape and used rustolium "forest green" spray paint.
Decals are not a big thing for me so if they came off i am not paying to add more, but that were not so i taped them
Discussion Starter · #13 ·
Out of curiosity, what do you guys reccomend as a permanent paint coating?
I had to wire wheel off like 50% of the bikes original powder coating due to alot of rust.
The "industrial heavy duty" rustolium gloss black paint I used is not as resistant as i thought to scratching or rubbing.
Anyone got a better, more durable (yet cheap) recommendation? I heard about mixing "paint hardeners" in with other paint ts, but looking for other feedback.
Durable and cheap? You might try adding a catalyst to Implement paint from Tractor Supply. You'll need to prep (& prime) the surfaces perfectly beforehand though. Use a medium-heavy coat of self-etching primer over clean derusted steel. Sand lightly for a bond after it is dry, wash with prep-sol and shoot your parts. Allow them to fully cure for several days before handling them.
1 - 16 of 16 Posts
