Picked up a 1993 fourtrax 4x4 without spark.
The guy I bought it from replaced the coil, cdi
I tested the pick up coil & voltage regulator which all tested ok.
I just have a question about the CDI box is there a difference between a 1993&1994?
Both parts plug in & it seems he installed a 1994 cdi would this posisibly be the issue?
Below is the cdi part numbers
30410-hc4-770 & 30410-hm5-505
Thanks
For a guaranteed answer it may be worth dropping Ricks Motorsport Electronics an email or call. I can't be 100% sure but I think there are three, 89-93, 94-97 & 98-00.
Maybe somebody here can clarify.
Jeez!! Partzilla aren't cheap are they! I'd use Ricks, he's cheaper and still good quality. You can get a hot shot from Rick cheaper than the standard item from Partzilla.
