1992 250x Rear Axle Nut Removal
First just like to start by saying hi. New to the forums and new to quads. Been reading the post and this is a great site.
For a winter project I picked up a 1992 250x ($400). It runs OK but needs a ton of work. The previous owner did not take very good care of the machine and I found it his barn collecting dust and starting to rust.
The first thing I'm trying to tackle is the rear axle bearings. Or after reading post on this site, I'm guessing I'll be replacing the bearing carrier. The problem I'm having right off the bat is getting to the outer axle circlip to remove it. Am i supposed to turn the axle nut first to expose the clip? I read something (on another site) that said I had to turn the nut to expose and remove the clip but no mater how hard i try the nut will not budge. Its a bit rusty so I've been spraying it with WD40 but so far no luck.
I'm sneaking this post in while at work so i'll post pic's when i get home.
Any help at all would be great.
PS. I'm a total NOVICE so use "little" words!
