I have a 1992 Honda 300 4x4 when it is going through a mud hole or over a tree or something like that it will not spin 25” mud bugs even in first gear it feels like there is no power when it is under load. I have cleaned carb. Put fresh premium gas in it. Put new spark plug in. What would you guys suggest. Thanks in advance
if your tires have hudge lugs ?, without a gr ?, your..well..no pun intended..spinning your wheels !..lol. you can find great help on this issue here ----> www.atvhonda.com, please make a post in new member section, then make a thread in the correct section for your atv.
It's should turn 25s... see if it will hit the limiter or damn near in any gear on gravel once you know it's not a carb/fuel issue it's your centrifugal clutch weights that are worn out... 300 should be able to turn 25s in pretty much %90 of mud... my 300 had 25s and I tried to pull out a brute force and all it would do is bog out.... replaced the clutch weights and now all it will do is wheel hop NO MORE BOGGING!!!
just saying 25's will turn no problem ?, does not mean anything. all depends on how tall the lugs are on those 25's ???.
He said talking about 25in mud bugs nothing crazy and I'm just saying my experice with this stuff I doubt he filled it with water instead of air 😂 Now that would be a good one
it would not surprise me !!..lol.
