Ok, so my main question is:
will a coil from a 1999 trx300fw work on a 1991 trx300fw? they are different part numbers... 1991 vs 1999 but i dont know if that is simply a physical difference, or if the parts will not interchange for other reasons..
the reason i ask, is the last time i was at my camp(heart of winter), i couldnt start my quad. it had absolutely zero spark.. which i found odd as when i had parked it 3 months earlier(summer). Im about to go up to camp again, and i hope to fix it there, rather than bring it home.
I'm suspecting it is either:
mice got into wiring
bad coil
bad cdi
so my secondary question is: do you think it could be anything else? i bought a cheap aftermarket cdi to swap in, i also want to take up a replacement coil (hence my main question). I did see that there is also a "alarm module", which apparently is for the oil temp? but im unclear if it will lock out spark if it goes bad, or if it just operates the indicator light.
i suppose it could also be a bad kill switch? any way to quickly test that?
my plan is, toss in new coil, see if i get spark, new coil, test again... search for bad wires. any other diagnostics i could do would be great!
thanks for your help!!!!
bad coil
bad cdi
