1 - 10 of 10 Posts
Good Evening. I am a new member with many questions. I have a 1991 Fourtrax 300 4x4. I had top end rebuilt and carburetor cleaned.(At least that is what the mechanic told me.) It has a new starter, solenoid and battery, My problem is, while riding it stalls out. I can get it started again after priming the carb about three times. I will ride for another 15 -30 mins and it will stall again. I appreciate all suggestions.
Thanks
Sounds like a piece of trash still in the carb or maybe the vent hose on the gas cap or a fuel filter, and welcome to the forums.
Thanks for the updates. Do you recommend a fuel filter that I can add to the system? Also, there is no vent on my gas cap. Can I pry the on/off metal switch off the gas cap, drill a hole and add a vent hose?
Thanks!
The switch on the gas cap is your vent make sure it is in the on position, if in the off position will run a little while and will shut off cause the fuel can not flow with out air getting into the tank.
1 - 10 of 10 Posts
