When I first introduced myself, I wrote a bit about my NTM TRX 350.
I was warmly greeted and promptly treated with much kindness and generosity.
When I went to buy this machine, it would not start, but had fuel and spark---but no compression. So, I suspected valves or rings. When I got it home, I put my comp guage in the hole and with the carb already off, I guess I would have had WOT. Nothing would register on the guage. So I tore into it, expecting to find lots of problems and horror stories. The one thing I did not do was take a look at the cam timing before I removed it. I gave myself a hardy kick for that oversight. Anyway, the upper part looked great, and when I pulled the head to look at the piston and valves-but for a bit of carbon on the head part and around the ex valves, the piston top was nice and clean and even shiney(what gives here??---can an engine that has been run for any time at all still have a clean piston top. The wall is nice and smooth if a bit glazed with no marks whatsoever. So I stopped right there in the teardown. I removed the ex valves and cleaned them up and looked at the guides and seals--great shape---WTF--- no need to even remove the intake valves, they looked so good, and were absolutely air tight.
So--I decided to put it back together--even using the same head gasket because it is a holiday weekend and I could not get one. Comments on that please--I just want to get it together and see if I have any compression.
Now, when I removed the cam chain tensioner, I noticed that it was run full extension--so I am assuming that the chain has reached its wear limit and MAY have been loose enough to let the cam jump out of time. Either that or the PO, or someone did not get the timing correct the last time.
This engine has definitely been apart and put back together, and it may have had a new piston. The two sides do not match the texture of the long block, and I may have a much younger(or older) engine than the 20 year old ATV itself.
I am going to put the top cover on and then do a compression check to see if my theory is correct. If I get compression, then I need to ponder about getting a new cam chain and possibly a new head gasket.
Sorry for the long disortation, but I would be most interested in any comments. I want to do this right and will welcome any suggestions.
Thanks
Thanks
