New guy here looking to replace the tires on my 90 fourtrax 200. The fronts look good, but it needs new rears. Heres my problem. The tires that are on the rear now are 21x9x8. The manual states that it came with 22x9x8. I found a chart on mudthrowers.com that says it needs 22x10x8. From searching around I have found a wider selection in the 22x10x8. Will they work?
Welcome to the forums. Yes, they will work. 22 is the tire diameter, 10 is the width, and 8 is the rim diameter. As long as the last number in the tire size is "8", then it will fit your 8 inch diameter rims.
Yeah, they call those Fourtrax 200D Type II. I have no idea why they call them "Type II", though.
