Looking for some help on diagnosing and repairing brake noise on a Honda Fourtrax 300 (1990). I have taken brake drum off, cleaned, checked brake drum and re-installed. Pads are only about 2-3 years old with low miles. With brakes losened up all the way, so the don't work, the brake pads rub on drum when turning. When I had it apart it felt like the axle had too much play. If this is the case, do I need to replace the bearings holding axle or most likely replace the bearings and axle? Anything else that might cause the axle to have more play than it should? Have a Climers manual so I think I can tackle, just want to figure out what parts I should order to replace.
Thanks.
Thanks.
