Im selling my Honda trx250r quad I just spent 1,500 on it this summer for updateing the pep clicker shocks by buldwin performance and a complete motor rebuild (new crank, piston,rings, bearing,gaskets, 100%NEW and also new rubber front and back Holeshot MXR6's) LRD claims 63WHP and trust me it flys!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2002 Laeger farme and swing arm. with CR500 link Nice deep power coat on it I was told it was a narrow frame but just found some pics online of a narrow frame and mine is different so I think it might be a wide frame
+2 Lonestar A-arms
+2 chrome tie rods
new tie rod ends
+2 stainless braided brake lines
Polished janson brake line clamps
PEP front clicker shock with remote res just rebuilt and valved for 180LBS rider triple rate springs. Shock were updated with the larger shafts Have all the paper work
PEP rear clicker shock remote res
Shock covers for the pep shocks
after market grab bar polished
after market front bumper
AC Pro peg Nerf bars
Clark gas tanks
Flex Bars with anti-vib will take off $100 if you want a set of renthals instead
MSR quick adj clutch leaver
Nac's front brake cover Polished
Nac's thumb throttle cover Polished
Nac's E-brake block off plate Polished
Pro Grip grips
ITP Baja rims
HoleShot MXR6 tires NEW front and back
Ricky Stator 200w lighting coil
Janson power coil
Radiator air shroud
Chrome steering steem
Pro Design power shifter
Polished stator cover
Polished clutch cover
Hinson rear brake leaver
Rath case saver Polished
Hinson Clutch basket
38mm Keihin Air stricker carb
K&N air filter with pre filter
Boyeson RAD valve with new pedals
TM design works Slide-N-guide
+4 domenator rear axle
Anti fade nut
Modifyed Kick starter with padle
All Chrome allen hear bolts on everything
LRD350cc power Valve engine
LRD Big Bore pipe for the 350 kit
LRD performance speciaities slincer
Cyl is fully ported by LRD
Engine was just rebuilt top to bottem with summer only 10hr on engine and shocks and tires
New piston
New piston rings- pin and bearing
New Hot rod short rod crank
New crank bearing and seals
All New gaskets and seals
Pressure teasted engine before start up
Cylinder was bored out last summer and was in good shape but it got a fresh hone and a new piston again just because I was in there. There is tons and tons of cash invested. the only thing it needs is a rear brake rotor because it is worped but still works. i really dont want to sell it but I just bought a cobra and a house and just cant keep it any longer. theres just not enought time for all the toys $5,500.00 for best responce call 920-277-6905 or email me at [email protected]
PICS http://profile.imageshack.us/user/highlyboosted/
+2 Lonestar A-arms
+2 chrome tie rods
new tie rod ends
Clark gas tanks
Pro Grip grips
ITP Baja rims
Janson power coil
Radiator air shroud
Anti fade nut
New piston
