New cdi new stator new pick up coil new volt reg/rec new battery. I ohmed out all the wires in wiring harness, both fuses checked with a meter. Kill switch and ignition switch checked with a meter. No spark I’ve narrowed it down to one of two things 1) bad starter motor not cranking fast enough. 2) bad magnets in flywheel, with either stator all I can get is 5-6vac I know this is not enough voltage to get the cdi to fire. So my question is has anyone has this problem before? If so what fixed it?
