Hi, I have a 1988 Honda foreman 350 and recently I have not been able to get it to run. I have replaced the battery and starter a couple months ago, and now am having fuel delivery issues. After checking the leads that go to the fuel pump, I get 6 volts, which is not enough to power it. It pumps fuel with a consonant 12 volts, so I know the unit works. I’m not sure if anyone else has had the same issue, and not sure if there is a bad relay, or a bad wire??? If anyone has a solution, or advice I would appreciate it.
