I have a 1988 Honda 350 4-wheeler with front brake problems. It has hydraulic brakes with a small master cylinder next to the brake lever. The problem is the front brakes seem to be locked up. The brake lever has no resistance and compresses fully with no effort. I have filled the reservior which was nearly empty and tried to bleed the brakes with no success. I removed the wheels and the axle nut and tried to remove the brake housing but it seems to be stuck like the brakes are extended holding the housing in place. Do you know where I can find an online schematic of the brakes or can someone tell me what is going on?
Much thanks, David Cochran, TN
I would recommend getting a good repair ,manual by Honda. You could try backing the breaks off with a scrudriver.
Number 22 is what you will be turning to back them off.
You will also need to remove #12 in order to get the hub off.
Welcome to the forums.
Welcome to the forums.I agree with them.
