having issues with my trx250 starting. Can only get it to kickstart. With the key in the off position it will kickstart right up. Turn the key on and nothing. No lights nor will the starter turn or even click. New battery and fuses look good. Only way to shut it off is kill switch on handle bar. Needing some suggestions. Thanks
sounds like to me your ignition switch is china ?, bad ?, if should not even start at all if the ignition switch is the correct switch, and good ?!.
