It’s probably a pretty dumb question but, are both of the one way bearings the same on a Honda frourtrax 250?
Your Thread title was a poor choice BTW. Why not “YEAR TRX250 One-way Bearing Question”
Check part numbers they are likely different and not interchangeable.
One Way Bearings are designed to transmit torque between the shaft and housing in one direction and allow free motion in the opposite direction.
Oh, okay thanks for the tips, I’ll look at the parts numbers. Have a nice day👍
Here ya go check it out I don’t know if this is your model. Part numbers are different; even look different.
Ok now consider even if they were the same—could you swap sides?
If the engine rotates counterclockwise when looking at the left case—in what direction is the engine turning from the right side perspective?
151291
151292
