All 3 legs of the stator measure 0.9 ohms and not continuity to ground. Stator passes.
you need to pull the light switch apart, and inspect the kill switch. have you tested the fan control unit ?, replaced the fan control unit ?. if its bad ?, you will never get the spark plug to fire.All 3 legs of the stator measure 0.9 ohms and not continuity to ground. Stator passes.
