Could not suck it out with a hand pump. finally pressurized the tank through the gas cap vent. Some powdered rust came out before clogging. Will try more. Do you have a plastic tank recommendation?
Thought I would let you know what finally worked on the tank. Used Muriatic Acid. Strong stuff. Right fuel line was plugged. Used Heavy Weed Wacker line and drill. The last 3" was a heavy black tar like substance. Weed Wacker line is good because it is tough. Can take a lot of twisting. Used at least 30 strings a foot long+. Every 5 string or so I would apply air pressure with a coned shape rubber head on a blast nozzle. Eventually broke through with air. Ran several tanks of air through the line. Drained muriatic acid and flush with water 12 times or more. Until particles did not come out and only pure water.
As bad as the Tank was I assume the carb is just as bad. For a rebuild kit do I just need the gasket set 16100-HA7-772 Or do I need more? Also I am at 6500 ft elev and will use this at 9000 ft elev. Do I need different jets?
I will get you the o ring specs and jet part number tomorrow.
Stock is 142? and they recommend what I cannot remember.
In my first 86 i run a 138.5? at 3100-4000 ft it does well. I’m going to swap over to the 142–because my second 86 runs real well. It really helps to just have a spare carb
Ok, Took a break, Back on it. Tank reinstalled, ordered carb gasket kit. Is there any maintenance on the fuel pump. I did electrically bump it and it runs. Do not want to run without fuel. As bad as the tank was I am concerned about the condition of the pump and carb.
Do you have to prime the fuel pump in a dry system. Tried to pump gas from the tank and routed a line from the pump back to the tank. Pump makes sligt chattering noise like it is trying. But does it give enough suction to pump from the bottom of the tank? Have about 2 gallons in the tank.
Got my new fuel pump today. It pumps like a champ. The old and the new sound the same. Could not suck fuel with the old, can with the new. Getting closer.
Started on the carb today. Could not get the choke disconnected so working it on top of the frame on a board. Screws very difficult to get out of the bowl. Had to use an impact driver. The carb was full of water, just like the crankcase and fuel tank. Last place this ATV must have been was a river. The "baffle" seems very loose. Is this normal? It seems to have a slot that it fits on. But nothing seems to hold it in place. Other wise cleaning the bowl and will reinstall. Will try to get new screws.
Yes the baffle fits loose just be careful that it’s aligned properly when installing the bowl or you might damage the baffle.
how does the passage plug look?
I always spray my carbs with Deep Creep, put them in a ziplock bag and chill them in a freezer. This helps contract the metal a bit. But you need to get all the water out first.
If you strip a screw you may be able to use a dremel cutting wheel to cut a straight bit into it.
K&L sells a carb kit with all the screws, jets and gaskets. I don’t usually recommend aftermarket but this is a good kit.
Find many great new & used options and get the best deals for K&L Supply - 18-9307 - Carburetor Repair Kit at the best online prices at eBay! Free shipping for many products!
rover.ebay.com
81 - 100 of 157 Posts
