I bought a 1987 Honda Trx 250x non running no spark or exhaust. I bought a new coil fixed spark, new exhaust now it won't start if I pull start it with another quad it starts right up in first gear then the second I unhook the chain it dies everytime, makes no sense to me I've pulled the carb clean it, chained oil, new plug, new coil, I was thinking possibly valves so I checked that as well noticed there is a metal piece that goes into the front valve and there is a cable that hooks to it that leads by the kick start is super lose I can pull it right out. Not sure where to go from here
The cable you mentioned might be for an automatic compression release operated by the kickstarter. I am not familiar with the early 250x so I'm not sure. You can get a copy of the service manual for your bike HERE and fix or adjust that.
I'll take a guess on your ignition problem... but don't rely on me alone. The motor has to be kicked over at 430 RPMs or faster for it to start, so if the motor dies right away it might have a bad AC regulator or a bad harness plug connection preventing the alternator from working. Check and clean all of the harness plugs and any ground wire going to the frame. See the attached image for reference and initial ignition system troubleshooting steps.
Let us know how it goes and welcome to the forums!
i have checked the service manual and it is the decompression lever. Everytime I kick it over the decompression shaft comes out about a 1/4 inch. I made sure the cable is tight but does not help. Also I have checked all the wireing everything looks good, checked all the grounds. And I have plenty of spark but still does not want to run on its own???
While replacing a gasket on head noticed that the chain inside had rubbed on the top of the head gouging groves into it where the chain hd rubbed against the head. Could the timeing chain be too loose and messing it up?
The timing chain has probably jumped over the upper sprocket by now, putting the valve timing out of time. You'll need to replace the chain & sprocket to get the motor to run if thats the case. Check the cam journals for excessive wear too, while you have the rocker cover off.
The service manual covers chain replacement well. Make sure you adjust valves and the decomp cable when you get done...
And have fun!
And have fun![/QUOTE
Ok thank you now if that's the problem that would cause it to not run by its self, it still runs hardly while pulling with another quad but won't stAy running on its own power
I would start with a compression test. The decomp cable won't prevent it from starting unless it's too tight. Check your valve lash also .004 intake and exhaust. If they are too tight it will be a hard start.
