Hello. I'm new to the thread and joined to see if anyone could offer me some of their input on this issue. This problem has plagued me with this bike for years now. It is a great running machine, when it is willing to run. I have three of these old Hondas, an '86 TRX350, an '87 TRX350, and my "87 TRX350D. Here is the problem that I have been dealing with for the past 6 years. On occasions, the Honda starts fine. Sometimes it will run with no problems at all and I can ride all day without a single issue. On other occasions, it throws these weird temper tantrums where it will partially start, partially run, then die. I will then have to mess with it for a while, when out of the blue, it will start to run normally. Sometimes it will run fine but sometimes it will die while riding it and I have to repeat the process. I have been dealing with the issue for years now. About a year ago I parked it because it needed a front wheel bearing. It sat for about 5 months as I couldn't find the time to do it. Went to start it and I couldn't get the pump to pull fuel. Figured maybe the shutoff on the tank was plugged, and put it off until I had the time to delve into it further. A few weeks ago I found the time to mess with it, pulled the lines off the pump, sucked on them, got the pump to pull, and well ah. Problem solved. Ran great for a couple days, and I got to thinking that maybe that was the problem all along, until it decided to start throwing its fits again. I noticed that sometimes when it throws it's fits, fuel runs out of the overflow hose. Now I'm thinking it could be a carb issue, but all these years I've thought it was electrical. I found this YouTube video and this gentleman appeared to be having the same problem, and what mine is doing is very similar to this. Here is the link if you would like to see what I am trying to describe:
He apparently traced it to being old fuel but I suspect that wasn't the case and I know that's not the case for me.
Any suggestions and advice on this matter will be greatly appreciated!
Thanks again,
-Morgan
Thanks again,
-Morgan
