1 - 10 of 10 Posts
I have a 1987 Honda Foreman 350D that I need the fog light harnesses for. I am hoping that someone may have a set off a parts bike that they are willing to part with. In case it helps the ship to zip code is 98296. They should’ve little short harnesses and they may be unique to 1987 350D’s. Thank you in advance.
the 1987 trx350D foreman does not have fog lights, they have sub lights, ( CLEAR ). the 1987 trx350 fourtrax does have the fog lights, but the harness for them are on the wire harness, not the lights. @alloutdoors, most parts for these are discontinued today, ebay used ?, or salvage yard.
Reactions: alloutdoors
There are no sub-harnesses on the sub-lights on the 87 TRX350D. You'd need to buy used sub-lights (which include the bulbs, sockets & boots) then just plug them into the main wiring harness. You can check with powersportsnation & eBay if there are no ATV salvage yards nearby for a used set of lights. They'll be pricey I imagine.
Discussion Starter · #10 ·
I should have what you need. I've got several 350 parts bikes.
You just need the harness then?
Thank you! I did, I wished I'd seen your note earlier. I found a used set of light assemblies with the harnesses set on Ebay that I purchased already for $60 shipped. They appear to be in pretty good shape, hopefully they are.
However, I will keep you in mind for other items that I may end up needing as the project continues!
Do you have any tips on fixing the muffler. The one on the bike has rotted out area around the clean out access hole, and the replacement I received from another seller on Ebay has the same issue. I was thinking of getting a clamp like this to try and cover the hole but I'm not sure if it'll do the trick or not.
https://www.amazon.com/gp/product/B077TBQNN1/ref=ox_sc_act_title_1?smid=A1W30H4E1OR4L&psc=1
Thanks in advance!
1 - 10 of 10 Posts
