Hello everybody.
I recently purchased a 1987 Honda 250X FourTrax. It had been sitting for a year or two before I bought it and thus would not idle properly, so I cleaned and rebuilt the carburetor. Now, it stays running at idle but has these problems:
1. the RPMs vary up and down more than I feel that they should
2. it backfires out the exhaust quite a bit (it did that before the rebuilt as well)
3. the throttle response is a bit hesitant if it is accelerated hard from idle
4. the exhause head pipe glows orange/red sometimes
I have done a bunch of maintenance, all to no avail:
1. adjusted valve clearance
2. cleaned/oiled air filter
3. adjusted carb pilot jet screw (does not seem to make much of a difference in the run quality) and idle screw
4. adjusted throttle cable
5. new gasoline
6. new fuel filters/fuel line
It seems that it must be running lean (at least at times) because of the head pipe getting hot enough to glow.
So, is it possible that the carb is wore out and not responding to the adjustments or quick throttle inputs and I need a new one?
If so, what are the differences between the carbs for the different year 250Xs and the 300EXs? The repair manual I have states different pilot jet screw settings for the different year carburetors, which leads me to believe that there are some differences between some of the carburetors.
Or does anybody have any other suggestions or things to try?
Thank you for any help.
5. new gasoline
