hello, I purchased a so called running engine off ebay, after a new carb, intake, unstuck neutral safety I got it running. the problem is the shifter seems to stick and not return to normal position, also when putting it into gear it dies. you can ride it but doesn't want to pull like it powers out or stain on engine. I have adjusted to clutch per Honda and doesn't seem to Help, I'm trying to get going for grandson any help would be great, Leading toward clutch pack problems and shift detent spring.
