First time posting long time rider. I have a 1986 TRX350 with a bad oil temp sensor. I recently tried to order the direct replacement but it is discontinued. Several on line honda parts suppliers say I can use the same temp sensor as my 2006 TRX500 has. It only has 1 wire on the 2006 unit. Can the sensor be used on the older TRX350 machine? If so how should it be hooked up??
