Hey guys, I just bought an 86 trx125. I bought it knowing that two of the gears in the sub trans had teeth missing and needed to replace the gears. (the two gears are the 32t high drive gear and the shaft reduction gear.)
My problem is that they are discontinued parts and no one I could find has them in stock. I have scoured the interwebs for used parts and have been unsuccessful in finding used ones.
My question is if any of you know where I can find the two gears? My second question is, what else can I use to get my atv running? Like parts from an atc125 or something like that.
Also that previous owner tried to fix the gears by filling in the broken teeth with a welder and then grinding it down to make new teeth. Its not pretty and if I used them I wouldn't trust them to work for long or at all but what do you guys think? I could post some pics if you want.
Thanks for all the help.
