no I checked continuity of kill switch with it still plugged in. I followed your instructions tho and re checked unplugged and there is no continuity unplugged, with the key on (green light) I will check the pulse generator tomorrow. two questions. 1. is the kill switch okay (even tho its stuck on the run position) and 2. is the cdi okay since it is sending voltage to the pump relay, but the fuel pump does not run.
Ya, when checking continuity of any and all switches, the switch must be disconnected from the circuit. Continuity tests are in reality resistance tests and use the resistance (ohms) reading function in your meter to indicate whether a switch (or circuit, depending on your measurement target) is OPEN (no continuity) or CLOSED (Continuity). Measuring a switch while it is still in-circuit includes other components within that local circuit loop, so its misleading and useless information you'll receive from that test.
I'm sorry about not being more clear with instructions. Luckily though, my oversight hasn't cost you any of your hard-earned cash, just some of your valuable time.
To answer question #1 -- Yes, the kill switch is fine if it has no continuity while unplugged, even though the sliding switch doesn't move from the "Run" position. You can plug the handlebar switches assembly back into the wiring harness where it belongs for the remainder of testing. You'll need to use the electric starter button to crank the motor over fast enough for the pulse gen to work good anyway.... So plug those switches back into the harness where they belong.
You can come back later after the motor is running to disassemble that kill switch and fix it. It has a rusted/corroded or missing detent ball in it and is easy to fix. Ask about that detent later on if you need any help with that...?
Answer to question #2 -- We don't know anything about the CDI yet... cause I screwed up during these continuity tests when I forgot to tell you to disconnect switches before testing. We gotta start over, sorry about that. :-(
So, now that we are back at square one with intent to do things right...
Next test in the logical order is to unplug the Ignition switch from the wiring harness and check for continuity through that switch for each color-pair of wires according to the table in the manual. Note you'll be checking that switch in both the "Off" and "On" positions:
