Hello, I am new here and I have an older 86. For several years now the four wheeler has had some noise coming from the engine but we just use it on a farm so we didn't pay much attention to it. A few months ago it became worse and will not run now. I removed the valve cover and it seems that it has jumped 1 tooth based on the setting the crank to the "T" mark and the timing marks on the camshaft. The chain is quite loose on the camshaft sprocket. Through my investigation I removed the timing chain tensioner and it was fully retracted (within the body of the tensioner), it was not extended at all. I can take the bolt out of the back and use the screw force the tensioner out, but other than that it won't move. To me, this doesn't seem correct and I would think the tension would extend out if there was no force pressing against it. I have a manual for the bike and I have searched the web but I can't seem to find anything that explains how it works. Before I go any further and start disassembly the engine I would like to understand how this mechanism works usually.
Does anyone know how this tensioner works normally?
Should the tensioner extend out fully if a force is not present?
Thanks
Discussion Starter #2
Here is a picture of the tensioner. This was the position when I removed it from the bike. I think it should have been extended out.
You need a new timing chain.. OEM or DID are you best options. Don't cheap out and buy an Amazon/eBay China cheapy, you'll regret it!!
Discussion Starter #4
Hi Sam, thanks for the reply but that’s not related to my question. Do you know how the tensioner works?
Thanks
You're right, it should have been extended out. No good! REPLACE! There's a ratcheting system that has failed - it should automatically tighten.
Danier , ---- the tensioner is spring loaded , if you were to take it out the jug , let it spring into the loaded position and stick it back into the jug , then you should have at least 1/4 -3/8 gap , if it goes all the way in flush with the block then the timing chain is worn out
there is a screw in the end of the tensioner , usually 8MM , take it out , put a small flat head screw driver into the hole , turn the driver and the spring load will retract , let it go and it should snap back out
