Check
this post out and see if the info in there helps..?
Basically, if you want to change the front rims from stock you'll have to check for rim clearance with every different offset that you find. Its gonna be a trial & error fitting perhaps. The bolt pattern should be the same on all 4 bolt Honda rims, so that gives you an awful lot of different rims to try....
