if your fuel pump is '' ticking '' or '' pulsing '' ?, then your fuel cut-off relay is working.I see well ever since i have had this unit, the fuel pump has always ticked when you turn the key on. At least until it recieved back pressure. Yesterday i was finally able to get into the fuel relay box (the screws were rusted BAD!). I pulled the Bl/Y wire, tried to crank and i had no visible voltage with meter and test light. So, from your explanation problem lies within the fuel cut off relay, correct?spark starts at the pick up coil, then goes to fuel cut-off relay as a pulse signal, this signal then goes to c.d.i., then to spark plug coil, then spark plug. the c.d.i. see's the pulse from the pick coil off the crank so to speak ?, when the pulse returns from the fuel cut-off relay, the c.d.i. then fires the spark plug coil. in other words, the spark plug coil see's this pulse from the pick up coil signal, that comes from the fuel cut-off relay. this is a safety feature Honda built into the atv, the fuel pump should not work unless the motor is running, or cranking over ?. so if you wrecked, and the atv is up side down, and stalls ?, then the fuel pump will shut off, cutting down the risk of a fire from leaking fuel.Ok so does the spark come from the cdi to the fuel relay then to the coil? Or does it come from the fuel relay to the cdi then to the coil?
Sent from my SAMSUNG-SM-G890A using Tapatalk
