i still think, dont buy china.. maybe, rebuild, a used carb. that is OEM. others will talk soon..
i am interested if there is a way, to get needle out, or how a needle got broke..
i might learn something.
if its the air/fuel mixture jet needle he's talking about ?, nope..never..not gonna happen !. once the tip breaks off in the carb body ?, that carb is trash..paper weight from then on, it can not be fixed..no way at all !.
That’s pretty common for the pilot jet on those to break off.
Is that a Keihin QA04A? The parts listing only shows part number 16100-HA8-023 and 16100-HA8-033.
anyway, you should be able to find them on fleabay for about $80 to $125 but look carefully at the model number in your service manual some sellers will only know that they took “this carb” off of an 86 250. And make sure their jets aren’t also broken off
Here’s one with that honda part number but as you can see the seller has unintentionally covered up the model number
If your stuck an ATC carb would work, as would a 300 fourtrax. You'd need some minor changes but would certainly be a MUCH better option than a China knock off carb.!
This might sound like a stupid question but does the vent tube from the gas cap that runs down in front of the tank simply slide in and out? Mine rotted (2004) model and broke off where it slides down past the tank. I didn't want to just pull it out not knowing if it was connected to something...
Looking to get some input on putting some LED pods or light bar on my 86 350. Just wondering how many watts I can safely pull without hurting anything. I am currently running halogen bulbs besides main headlight is an LED. I will also be hooking up a winch, not sure if that is going to hurt...
Hello,
I have a 2014 TRX420FM1 4X4 that I use primarily for ice fishing. I've always had trouble getting it to start when its been sitting outside for awhile in temperatures below 0°F. I am OK on cold days if I just start it up once and awhile and let it run every couple hours when its really...
If it ever gets here in the Great lakes region!! lol
Rachaels been fluid filmed, plow mounted, new shoes, and a reverse light mounted and triggered only in reverse gear.Was gonna re-spray paint the plow, but thatll be this spring.
Hmm, just realized im missing my sand bags for the racks.. 2...
