1 - 2 of 2 Posts
Hello folks, I recently bought a 350d fourtrax an the starter would stay on when button was pushed, well I done some rewiring on the inline fuse an it was working properly. My question is now all a sudden it will engage the starter even if the key is in the off position an will not turn off unless you pull the battery terminal off? I've replace starter silaniod an still same? PLEASE HELP AS IM ABOUT TO PUT IT TO SLEEP 4EVER...
put it back like its suppose to be, then determine if the starter is bad ?, or the starter solenoid is bad ?, or a problem with the start button switch. '' jerry rigging '' will never lead to good things !. seen you started another thread, looking for a 1985 service manual ?, no such thing, this model was not made until 1986 !.
1 - 2 of 2 Posts
