Hi Everyone,
I've been lucky to pickup a 1984 TRX 200 free of charge but with no key and wiring harness is buggered.
What I'm chasing is a basic wiring plan to use the pullstart only and cutoff switch. No lights,battery,starter ect..ect..ect..
Many thanks
welcome to the forums. don't run it without a battery !. you should start with replacing the wire harness, buy a ignition switch, a good battery, then take it from there.
I'd love to buy new parts but living out in the country I don't have that luxury.
There has to be a simple wiring solution where once you pull on the pull-start it should generate enough power to run itself.
no key , wiring booger up , got it free = sounds fishy to me -------- word is , if you run it without a battery , then it will burn up the stator -------- finding parts for that bike can be a night mare , it was very limited production , might be best to "Let It Go"
