was running perfect saturday. Started right up on sunday made it about 20 yards and stalled out like it ran out of gas. Getting strong spark and compression, pulled carb and its clean. Gas flows fine into the carb and float is ok. Getting good compression in the cylinder and when I put my hand over the intake it feels like its pulling in air. However it is getting no gas. If I crank it over with the choke on several times, then pull the plug, its dry. Sounds like a carb problem, but I tried the same thing with the carb removed, and spryed starting fluid into the intake while cranking it 6 or 7 times, same result, dry plug. Doesn't seem to have any obstructions in the intake and it does have intake suction. Didn't make any weird sounds just sputtered and died. Any ideas???? Spark / compression / good carb//
