Any Foreman SRA rear rims will work. Also any 2001 to 2014 Rubicon rear rims will work. Your stock front rims will work as-is with those tires you just picked up.So, I’ve found a set of Polaris take offs for $150. The rears are 12”, and mine are 10”. Which factory Honda 12” rims will I need, provided I can find some used?
Thanks for the info. Been wanting to go to 12” on the rear for awhile.Any Foreman SRA rear rims will work. Also any 2001 to 2014 Rubicon rear rims will work. Your stock front rims will work as-is with those tires you just picked up.So, I’ve found a set of Polaris take offs for $150. The rears are 12”, and mine are 10”. Which factory Honda 12” rims will I need, provided I can find some used?
Another option, ITP Delta Steels can be found for cheap online, and look close to stock. That's what I did on the rears of my Rancher.Thanks for the info. Been wanting to go to 12” on the rear for awhile.Any Foreman SRA rear rims will work. Also any 2001 to 2014 Rubicon rear rims will work. Your stock front rims will work as-is with those tires you just picked up.So, I’ve found a set of Polaris take offs for $150. The rears are 12”, and mine are 10”. Which factory Honda 12” rims will I need, provided I can find some used?
Good idea; the Delta rims are decent looking too. Are there any advantages to the 12” rears? Only advantage I see with the 10” is a slightly better ride because of the taller sidewall height.Another option, ITP Delta Steels can be found for cheap online, and look close to stock. That's what I did on the rears of my Rancher.Thanks for the info. Been wanting to go to 12” on the rear for awhile.Any Foreman SRA rear rims will work. Also any 2001 to 2014 Rubicon rear rims will work. Your stock front rims will work as-is with those tires you just picked up.
