Where can i get a bigger injector for my rincon? Is there even one available or is it a bad idea? Im gettin ready to put an HMF optimzer and exhaust on it and want to get a lil more power out of it.
I though they just reprogram the ECM to compensate for the change in air flow?
A bigger throttle body means more air can flow, more air means more power!!!!
On a bone stock machine, this is what I would do...
Find a more free flowing exhaust, intake, more aggressive cam, and then a fuel programmer to adjust your air/fuel ratio. HMF should be able to get you going in the right direction
Yeah, when i get the HMF optimzer do you think it would be ok to run it with th spark arrestor out just until i can get my exhaust?
The optimizer isn't going to do much of anything but make you run rich without an aftermarket exhaust. You will be fine removeing the baffle/spark arrestor without the optimizer, these machines come some what rich from the factory.
