1 - 10 of 10 Posts
I rebuilt this bike from mud junk that didn’t run. Now it will start but blows out the throttle body. Valves are adjusted tdc on compression stoke ok and cam is set correctly under front cover with a new timing chain.
Is it safe to say the cam is bad?
Hmmm maybe it’s sticking. I replaced the valve stem guides tho and valves were straight. I know it’s not tight because it wiggles at tdc.
I have seen the cam face in mud bikes spin out of time before. I thought maybe this cam had the timing out a little.
Anything is possible on a mud bike! Sometimes thinking can be your worse enemy too... :)
Its rarely productive to make unfounded assumptions, so... does it pass the compression tests, wet & dry? Is the exhaust system clear? Piston not installed backwards? Valves straight and true with good match & seal to valve seats? etc. I've seen a lot of bad cams/lifters over the years, so I can verify as fact that when lobes wear flat, you'll see standoff above the intake.
You can easily measure the valve lift (at the valves) using a dial indicator. Add a degree wheel and you can verify TDC location (check for a bent connecting rod) and whether each cam lobe is good/bad, and verify valve opening & closing event timings, along with lobe center and lobe separation angle.
Retro you know darn well I don’t have any fancy measuring tools like that! Lmao
I did pull the head and did a backyard test by pouring gas over the valves to see if it leaked through and the compression valve poured gas thru it so I gotta lap that one.
I also noticed I had two marks on top my brand new piston which indicates that it’s definately out of timing so I’m gonna put another cam that I have laying around on it and see it that cures it.
intake valve struck piston, timing is off ?, spacing for cylinder not right, allowing less clearance for piston to rise higher, herby letting valve hit piston ?. my money is on timing or both.
from what I know, a bad cam won't let the valve hit the piston, but timing off will, or, a sticking valve. worn cams only mean no compression from what I've learned in my years. the only way a piston will hit the valve is if the valve sticks ?, or, the timing is off ?. worse case, the connecting rod bearing at the bottom is bad ?, or, the top of the connecting rod where the wrist pin is too far worn, and letting slack happen, then you have the piston hitting a valve.
Cam wasn’t very worn but the face with the theeth were off. I replaced the cam readjusted valves because the new cam made em really tight and I lapped that valve. She purrs like a kitten now sounds quiet like a new one.
Thanks for the help y’all I got lucky on this one.
sooooooooooooooooo..you had the timing off with the cam chain and cam chain sprocket then ?..lol. yep, you got VERY lucky !..lol.
Reactions: misterclean59
1 - 10 of 10 Posts
