1 - 1 of 1 Posts
Have a Rubicon 500 trx500fa 07 and when you crank it will idle you can give it gas and it will go until you go full throttle then it goes into limp mode wont go over 12 mph and it sounds like it's on the limiter it dose blink 5 times on the screen I replaced angle sensor and clocked it still having same issue what else could it be looked the code it shows up and it says the angle sensor I'm lost with it need help or just a direction to go In been thru the carb many times it's good it only dose it at full throttle you turn it off and then back on and it's good again till u go full throttle and yes i did reset the 4 wheeler using the shift buttons still same thing
1 - 1 of 1 Posts
