1 - 2 of 2 Posts
Hi, looking for some help. Seems to be no power to anything. I've replaced the battery and checked both fuses under the seat. We were riding it a couple weeks ago with no issues then went to ride the other day and not enough power to start so pull started. That worked for a couple days and now nothing. Can still pull start it but with the electric shift it won't do anything. No lights on anywhere just nothing. Suggestions? Thanks in advance.
with a good charged battery, and its running, use a volt meter set at 12 vdc, probes on battery, rev it up, see if the volts increase as you rev it ?, it not ?, then your reg/rec or stator is bad ?. unless your battery isn't fully charged ?, your elec shift will never work, the es models MUST have a fully, operating charged battery in order to shift.
1 - 2 of 2 Posts
