1 - 10 of 10 Posts
So i recently bought an 07 rancher es. I got a good ride out of it one night, then took it out the following weekend, and about 2 hours in, i could not shift down at all. I could shift up, but not down. The previous owner replaced the shift motor, which still tried to shift even though its not changing gears. It can be heard trying to shift down, but goes nowhere. I can manually change the gears with the emergency tool without any problems. I took the shift motor box cover off to find that the one gear thats basically 1/4th of a large gear was sitting too low in the box. When i pulled it off to adjust its location, i noticed the splines on the gearshift arm are somewhat stripped. My question: i can find a replacement shaft (arm) to put in, but i cannot for the life of me, find any information anywhere that points to how it needs to come out to be replaced. I know i have to remove at least the front crankcase cover, but i dont know what else needs to go from there. Any thoughts and guidance would be greatly appreciated.
Do you think the shift motor was not installed correctly by the previous owner?
Or is there a bad bearing on the reduction gears (2 large to small double gears)?
Or is the partial gear arm that goes on the shift shaft bent/stripped?
I just want to know what caused this failure.
The service manual says you have to remove the engine/transmission and take the front and back covers off to remove the shift shaft.
I might try to drill a hole through the partial gear arm into the shift shaft and thread a stud in, to save a lot of time.
If that does not work, convert it to a foot shift.
Discussion Starter #3
My best guess is a constant attempt to shift into reverse from neutral without pulling the engine brake (left handle brake). This is the first bike ive ever owned, so i dont know if its normal for the shift motor to attempt to shift it without pulling the lever. The splines on the partial shaft are stripped, at least enough to make it skip when i shift down. I just need to know if i can replace that partial by just removing the front case cover or if i need to dig deeper.
You need to download the service manual and check it out.
You have to take the front cover off the motor and then you can pull it out the front. The back end of the shaft is keyed and fits into the angle sensor. So when you put it back together it's best to pull the angle sensor off the back of the motor first. Install the shaft then put the angle sensor back on.
Discussion Starter #6
Thank you Rocketman. Thats just what i needed to know. I really appreciate your help!
Before 2007 the gearshift shaft was the same between ES and Foot Shift models.
In 2007 they started making the 2 models with different gearshift shafts/spindles.
Apparently the new ES gearshift spindle is not attached to the back engine cover,
but the Foot Shift is (just like both models pre 2007).
The service manual in 2007 has an error in it at the start of chapter 11,
saying that the engine must be removed to remove the gearshift spindle.
But that is only true for the new Foot Shift model.
You do have to remove the centrifugal clutch before you can remove the
gearshift spindle shaft on the new ES model.
Discussion Starter #8
Thanks man, i really do appreciate your help!
Why would you remove the centrifugal clutch to remove shift shaft?
1 - 10 of 10 Posts
