Hi: First clean connector real good use compress air & WD40 you may have to do more than once to get all the dirt from behind the retainer tabs -- when cleaned push in both retainer tabs and pull & push with the other hand --- if that doesn't work use a pair off small needle nose pliers to squeeze in on the retainer tabs and pull & push up on the hose.
Reactions: retro
